trimming deatil views
When clipping detail views in a drawing I use -clipping profile view-, problem is;
a. When creating the clipping profile I want to use spline (not line as default) is this possible?
b. To clip a detail view you need to create a closed loop. I only want the trim line passing through the part to appear . My solution is to hide or delete the unwanted lines, but when you update a drawing they re appear – very annoying. Can this be avoided?
Thanks - Kevin
Thanks - Kevin
RE: trimming deatil views
Hope this helps....Cheers.
