conductor with varying size
Is there any code that indicates installing MV conductors of different size is not acceptable?If there is any code that violates this,I would like to use it to justify our intention to replace existing underground feeder.This cable are already old and obsolete(paper insulated).Thanks in advance....
RE: conductor with varying size
A splice in the middle of a conduit run is not acceptable.
respectfully
As far I know there is not code violation splicing different type of cable with an appropriate joint such as the one enclosed by Prysmian (former Pirelli US) http://www
Beware that the cable protection should consider the maximum temperature of the insulation.
On the other hand, paper cable still is available in the market.
