Vibrations from moving trains and pipes
We have a situation where sprinkler piping is to be supported from a structure over which moving trains pass.
Is there any data available on pipes, subjected to such vibrations, which tells us as to what levels of vibrations are acceptable so as not to cause pipe/joints failure.
RE: Vibrations from moving trains and pipes
I suggest you move this to forum378: Piping & fluid mechanics engineering. I think you will get a wider audience there and more likely will get a response. If you do decide to move the question, either red flag this thread, or post the new thread number.
Patricia Lougheed
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of the Eng-Tips Forums.
Want to post an image? Look at the FAQ's in forum559: SolidWorks 3D CAD products
