Discussion: punch connection of aluminum T-shape flange and FRP web
I am designing a composite I-beam: two aluminum T-shape flanges with short double stems and flat fiberglass reinforced plastic (FRP) sheet as web. The FRP web will insert to the narrow channel between the double stems. I am thinking using circular punch 2-3" O.C. to connect the FRP web to aluminum T-shape flanges. Could anyone suggest a better, really easier and more reliable mechanical connnection? Any input and discussion are greatly appreciated.
By the way, the composite I-beam is quite small, 3" (depth) x 0.5" (width). The thickness of FRP is about 0.110". The aluminum flange is about 0.080" and the short stem is 0.060". The load is appoximately 25-40 lbf/ft.
Any input about book references for design/summary of mechanical connection is appreciated.
Thank you,
Thank you,
RE: Discussion: punch connection of aluminum T-shape flange and FRP web
I cant really see the benefits of the FRP web in the aluminium caps, not sure of your situation, but thermal loads might put a downer on your idea.
B.E.
The expansion and contraction between FRP and aluminum is not a problem cause the coefficients of FRP sheet and aluminum are quite close each other. The major consideration to use FRP web is to get much better thermal-break web to improve thermal resistance. The loading is uniform loading of 25-40 lbf/ft acting at the top aluminum flange.
What I am looking for is to figure out easy and cheap mechanical connection method to hold these three pieces together to form a perfect composite I-beam. I try to figure out whehter there is any other easy and cheap method except punch method.
Thanks for you guys' input.
Wes C.
No trees were killed in the sending of this message, but a large number of electrons were terribly inconvenienced.
