modify model parameters on checked in part inside intralink
I have the task of 'fixing' a large number of parts that users have checked into Intralink that are missing parameters. I believe that my only course is to check out and open each then edit the parameters and check back in.
I see that a BOM_report can be done within commonspace - can is there a way of editing the parameter of parts from within Intralink without checking out each individual part?
Thx
S
RE: modify model parameters on checked in part inside intralink
If I remember right, you can edit them in Intralink if they've been designated that way.  It's been quite a while but I thought if they did show in Intralink, they were editable.
Fighter Pilot
Manufacturing Engineer
You can configure which parameter items are seen in commonspace. It's a little involved. Look in the Pro/E help, with some search terms like "configure parameters  in Intralink", and you should be able to find it. As fighterpilot said, if they show in Intralink, they're editable.
