SW API Help - change configuration of drawing view
First, the background - we have products that can fit into many applications, the same product can be used in several hardware configurations, so I have created drawing templates that we use, and all that needs to be done is to change the configuration of one drawing view within a drawing.  I would like to automate this process, but I just can't seem to find any way to write code to change a configuration of a drawing view.  Any help would be greatly appreciated.
Steve
Steven Danasko, CSWP
SolidWorks 2007 - SP2.2
UG NX3
Pro/Engineer Wildfire 2.0
RE: SW API Help - change configuration of drawing view
I use Lenny's "ConfigManager" macro.  It may not due exactly what you want, but the code example may help.
http://www.lennyworks.com/solidworks/default.asp?ID=20
Joe
SW Office 2006 SP5.1
P4 3.0Ghz 1GB
ATI FireGL X1
What is your experience level with API?  Have you looked at View::ReferencedConfiguration?
Handleman,
Not much experience at all.  I can write some simple code, but basically trying to learn as I go.
UG NX3
