Particulate matter in flue gas
Hello everybody:
In medium speed Diesel engines burning Bunker C (distillate Nº 6) the content of particulate matter in the exhaust gases of the majority (not all) of the engines has increased from some time ago and, its value is above the allowable upper limit.
The World Bank on its Thermal Power: Guidelines for new plants, shows that the upper value of particulate matter in flue gas should be less than 50 mg/Nm3.
The other constituents of the flue gas: CO,CO2,O2,SO2 and NOx are O.K.
Where can I find information/comments regarding with the causes that provoke this increment and what is a way to bring back these engines to their normal operation?
Thanks in advance for your comments.
RE: Particulate matter in flue gas
If your injectors are designed for true #6 but are having to try to burn this "feau" #6, that would cause them to do differently than they were designed for.
The problem with blended fuel is that if you got injectors that could handle what is in your tanks now, who knows what 'blend' the next batch might be.
Power Generators who burn heavy fuel oil have to deal with the same issues. Some have seen asphalt that ought to be on a road somewhere cut with a little diesel and pawned off as #6.
rmw
