Supported Video Cards, SW2008 and XPpro64
I noticed there are no certified cards on the SW website.  We are currently looking into a 64 bit xp pro workstation with a Quadro FX4500 card.  Will this card work?
RE: Supported Video Cards, SW2008 and XPpro64
If I select:
Certified
all vendors
2008
WinXP x64
and click - show passing
I get no results.
I get the same result as rjason71.
If I select;
Certified
All Vendors
All Operating Systems
Show Passing
I get lots of results, but none for XPx64.
cheers
That still does not work for me.
nVidia (or HP or 3Dlabs or Dell or ATI)
2008
XP x64
Show Passing
All yield the same thing ... nothing!
The info should be pulled from the same database. The Vendor, SW version and OS fields are just selection filters.
Can you post an image of what you are seeing, Scott?
cheers
I picked Nvidia, Win XP64-bit and selected the SW07
I got numerous hits
Quadro FX 3400/1400
WinXP x64      6.14.10.9136
WinXP x64     6.14.10.8167
That was just one of many others I selected
SW08 is not released yet so you won't get any hits.
Scott Baugh, CSWP pc2
www.scottjbaugh.com
Quote:
"If it's not broke, Don't fix it!"
Sometimes it takes a few weeks to months to get a list of VC drivers for a new version of SW.
P.S. I missed SW08 in the subject... need to go to bed earlier!!
www.scottjbaugh.com
Scott ... take a look at the title of this thread. smile
SW had a list of approved cards and drivers in the SW08 Beta forum. It is no longer there. That info could/should be made available in the main Video Card Testing link. Is it available in an EV list somewhere?
cheers
The reason I ask is we have a workstation that is 64 bit capable but is running XP32.  We want to convert it to XP64 and with SW2008 coming out soon, I wanted to make sure the video card would work.
We have a workstation running WinXP x64 and SolidWorks 2007 x64 with that card. Seems to run fine, at least I haven't heard any complaints from that user.
Don't know about 2008 but I'm sure it will work fine as that's a fairly new card.
Jason
SolidWorks 2007 SP4.0 on WinXP SP2
SolidWorks 2008 SP0.0 on WinXP SP2
