Samples for XM-28
Samples for XM-28
I am looking for a sample 1.25" to 1.5" diameter round bar 12ft section for XM-28 stainless. Carpenter makes the material as EnduraMet 32 or 18Cr-2Ni-12Mn, but they do not stock it and minimum order size for a mill run is something like 1600 lbs. Does anyone know where I can pick up this material? EdStainless???
Pete
Pete
RE: Samples for XM-28
http://www.univstainless.com/products/bar.aspx
You might also try Crucible Materials. I am not sure if they still make this grade or not.
Still trying to help you stop corrosion.
formerly Trent Tube, now Plymouth Tube
eblessman@plymouth.com
or edstainless@earthlink.net
