solidworks bom
solidworks bom
Does anyone how to add a surface area equations to a bom
to show in a column.
I know that there is a property for surface area, the only
problem is that it shows the surface area of the whole body.
all I need is one surface.
thanks
thanks
RE: solidworks bom
RE: solidworks bom
I'll give it a shot.
RE: solidworks bom
BOM?
RE: solidworks bom
In the DT, type $PRP@Area (or $PRP@your-choice) in the header of the column containing the area calculation and the value will be written to the parts properties.
In the BOM, create a column and reference that column to the newly created property.
The Help files have fairly good explanations of how to do this.
RE: solidworks bom
weldment tables as well?
