COUNTERBORE
COUNTERBORE
Hi everyone. I submitted this question August 28 and only had one
response. Let me reword the question. Figure 5-37 in the standard for
positioning a through hole and a counterbore hole with one positional
control. The question is, does the through hole and the cbore hole have
two different zones with the same tolerance size where the cbore hole
can tilt or shift in a different direction than the through hole, or
the two diameters must have one axis within one zone for the length of
both features?
both features?
RE: COUNTERBORE
RE: COUNTERBORE
Perhaps the committee violated one of its FUNDAMENTAL rules here in specifying a manufacturing process. Perhaps the proper way would have been to specify the diameters individually with the tolerancing as required to provide the proper clearnaces for the head and the body of the screw.
But as far as the example goes, I would have to go with a single tolerance zone for both features simultaneously.
RE: COUNTERBORE
RE: COUNTERBORE
ringman,
I don't see where there is a manufacturing process specified. What am I missing?
Powerhound
Production Supervisor
Inventor 2008
Mastercam X2
Smartcam 11.1
SSG, U.S. Army
Taji, Iraq OIF II
RE: COUNTERBORE
RE: COUNTERBORE
Chris
SolidWorks 07 4.0/PDMWorks 07
AutoCAD 06
ctopher's home (updated 04-21-07)
RE: COUNTERBORE
Dave D.
www.qmsi.ca
RE: COUNTERBORE
That said this often seems to be overlooked by others, many assume the Cbore & hole are automatically co-axial, this includes people that prepare standard hole charts etc.
My checker actually went through a hole chart we'd been using and made this correction. Of course now I'm not sure they match standard C'bore tools, sometimes you can't win!
KENAT, probably the least qualified checker you'll ever meet...
RE: COUNTERBORE
Counterbore is what the feature is called, like countersink or counterdrill. The tool and the process may share the same name, but the feature is what is being referred to in the standard. They don't care how you apply the counterbore, it just needs to be there. On a CNC mill, I never use a counterbore tool to apply a counterbore, I interpolate the larger diameter with an end mill.
Powerhound
Inventor 2008
Mastercam X2
Smartcam 11.1
SSG, U.S. Army
Taji, Iraq OIF II
RE: COUNTERBORE
It is my opinion, one axis for the length of both features:
1. Figure 5-37 states 0.25 positional tolerance zone for hole and counterbore. Not zones.
2. It does not make sense to have two axis going in two directions.
3. I think it implies one tool and one axis the total length of both features.
4. If the workpiece cost thousands and the two features were machined separately at different angles within the 0.25 zones with no assembly there would be litigation.
5. The bottom line is to state on the drawing next to the position callout the intended definition.
Gary
RE: COUNTERBORE
RE: COUNTERBORE
1. In this case the figure doesn't quite appear to match the paragraph. 5.7a explicitly states 'zones'. Given what paragraph 1.1.4 says about the figures only being illustrations etc then I assume the wording in the paragraph takes priority.
2. Within the limits imposed by the pos tol, why not? If as Powerhound details above the c'bore is made by a second operation the axis could be off slightly from 'perfect' however, so long as the resulting feature is still in tolerance, and was correctly toleranced in the first place, it would still work.
3. Wouldn't implying one tool contravene 1.4e as ringman points out.
4. I thought positional gives some control over the angle of the feature (figure 5-6). Hence if toleranced correctly in the first place then if the holes are in tolerance it shouldn't prevent assembly.
5. To my understanding by referencing ASME Y14.5M-1994 on the drawing and dimensioning as paragraph 5.7a then additional clarification shouldn't be required. By stating next to the drawing do you mean dimensioning as per 5.7c?
(Just to clarify I'm looking at ASME Y14.5M-1994)
I hope these counterpoints are taken in the spirit they were made. Obviously this type of discussion can be healthy as it can lead to clarification of the standard or improved interpretation of it.
Ken
RE: COUNTERBORE
Is the current practice to specify drill, ream, or punch for holes?
RE: COUNTERBORE
Also to be fair it is exceedingly difficult to create a stable and repeatable axis from a shallow counter bore without making huge assumptions about its orientation... so the axis, if checked for its displacement, is either generally assumed oriented to the axis of the deeper hole or assumed perpendicular to the datum feature.
All this considered... the liberties and constraints in the standard regard the features independently and make no inferences about processing.
RE: COUNTERBORE
1. The paragraph that I cited specifically says "zones".
2. It doesn't make sense to have the axes of the two features mis-aligned either but they are going to be, no matter how hard you try. The amount of mis-alignment that is permissible is up to the designer to determine.
3. Nothing implies the use of a single tool.
4. If the part is out of tolerance there SHOULD be litigation regardless of whether the part cost hundreds, thousands, or millions. If not, there shouldn't. If the counterbore is machined at the max inclination WRT the hole and the part doesn't work, then the tolerance is incorrect.
5. An alternative is to use the example in FIG 5-38 and tolerance the counterbore tighter than the through hole. Notes are never an option when there is a geometric tolerance available.
Opinions are the reason that standards were created; to remove the error in interpretation. There are a few things that are still not addressed in the ASME standard and are still somewhat open to interpretation, this however is not one of them. The paragraph I mentioned in my first post to this thread is clear in it's meaning.
Paul,
Amen to that.
Powerhound
Inventor 2008
Mastercam X2
Smartcam 11.1
SSG, U.S. Army
Taji, Iraq OIF II
RE: COUNTERBORE
A counterbore is essentially just a larger diameter step in a hole.
A couterbore tool or bit is a tool designed to create a stepped hole.
They are different things, I do not believe anyone else on this thread is donfusing the two.
RE: COUNTERBORE
Unless the CBORE is used differently other than for a screw or bolt.
Chris
AutoCAD 06
RE: COUNTERBORE
I agree, but in reviewing my old Machinery's Handbook it appears that counterbore is definitely a process using rather specific tools. Hence the question WHY DO WE SPECIFY THE PROCESS on drawings? Why not just the geometry?
RE: COUNTERBORE
http://
http://dict.die.net/counterbore/
While use of the word may have evolved out of the tool or process used to create the feature, its use to describe the feature is now so widespread and ingrained that it's not really specifying a process.
Ctopher, never say never ASME Y14.5M-1994 1.4e does allow processes to be on the drawing in certain circumstances. However it also makes it clear that it is generally to be avoided.
RE: COUNTERBORE
Powerhound
Inventor 2008
Mastercam X2
Smartcam 11.1
SSG, U.S. Army
Taji, Iraq OIF II
RE: COUNTERBORE
Man you really do your homework. I just finished up my post and noticed you had squeaked one in on me.
Powerhound
Inventor 2008
Mastercam X2
Smartcam 11.1
SSG, U.S. Army
Taji, Iraq OIF II
RE: COUNTERBORE
There are a lot of questions discusions I don't/can't contribute to due to lack of experience etc. This topic however, is something I've looked at before and discussed with someone far more knowledable than I, so I'm going to town.
That way when I ask a question hopefully people answer.
I'll scratch your back...
Putting, or even hinting, at processes on a drawing is a red flag for me, I'll usually go off about even a poorly worded note.
However, in this case I don't see putting Counterbore or |_| (that's meant to be the symbol) as implying a process.
On the other hand, someone says "DRILL HOLE .125" or DRILL & TAP 8-32" I'll slap their wrist!
RE: COUNTERBORE
1.The text in paragraph 5.7(a) stated “ZONES”, and the text in figure 5-37 states “ZONE”. Which one is correct? I do not know. That is why I said a note under the feature control frame may be needed if there is a chance that the wrong definition may be used.
2.If the two axes tilt in two opposite directions, you are correct the hole sizes need to be calculated.
3.I should not have mention an implied counterbore tool, I know we do not mention the process on a drawing.
Thanks KENAT, I need to be more accurate in my statements.
RE: COUNTERBORE
This is the first time I've seen the confusion amongst what I'd take to be mostly fairly knowledgable parties, so up to now it's not something I'd have thought needed clarification.
This may be something worth pointing out to the ASME commitee for consideration for correction/clarification. I strongly suspect the figure needs correcting but I could well be wrong.
RE: COUNTERBORE
I'll give you a star. Well said.
Chris
AutoCAD 06
RE: COUNTERBORE
Then the question, what controls the relationship for the seating surface for the screw, if not the process?
Comments?
RE: COUNTERBORE
Chris
AutoCAD 06
RE: COUNTERBORE
RE: COUNTERBORE
Your first point is covered in 5.7 b & c. However my preference is to have a single FCF and just make sure the Cbore dia is big enough to accomodate tolerances from all other features/components (as CheckerRon). As I mentioned earlier and CheckerRon says, this can end up ruling out a lot of 'off the shelf' counterbore bits. The use of a larger C'bore with looser tolerance achieves almost the same thing as a looser positional tol due to 'bonus tolerance'.
"Then the question, what controls the relationship for the seating surface for the screw, if not the process?
Umm, am I missing someting here? The tolerances on the drawing control the relationship.
The combination of the positional tolerance, the diameter tolerance and the c'bore depth tolerance should take care of this. If you aren't specifying all these then your drawing is incomplete. There are at least 2 common processes for creating a counterbored hole, either using a c'bore bit or creating the hole and c'bore separately as a 2 stage process. If the drawing is created properly and the processes done correctly both are perfectly good options.
Ron,
I don't think Gary & I quite agree. We both agree that figure 5-37 doesn't quite match the wording of 5.7a. The paragraph clearly says zones, the figure says zone. I believe that the paragraph takes precedence over the figure and so there isn't any ambiguity, the figure is just slightly wrong. Gary doesn't agree that the paragraph necessarily takes precedence and so believes it's ambiguous and should be clarified with a drawing note or similar.
What do you think?
RE: COUNTERBORE
KENAT, how would you like some side work?
RE: COUNTERBORE
I have side work, it's called trying to check for the other half of the business as well as the half CheckerRon used to take care of
CheckerRon might be interested though if it's any more than a joke.
RE: COUNTERBORE
My question with regards to the seating of the screw head on the CBORED hole, is based on the example in the standard. The only control that is apparently indicated is the one which controls the depth. The depth allowance quite probably could exceed the angular misalignment with the body of the screw. Where is the refinement, if not controlled by the tool? Perhaps the example in the Standard needs some refinement.
Lets not forget that the Standard is supposed to provide for a "universal' interpretation of drawings.
Another look at the example, and I ask "What is gained by the inclusion of the symbol for CBORE?. Would it not fly just as well without it?" There is a diameter and a depth.
RE: COUNTERBORE
If the depth of the cbore has a fairly large tolerance then yes, the bottom of the cbore could be at quite an angle.
If this is problem you need to add a tolerance (eg, perpendicularity to the bore or more likely parallellism to the surface) to correct it.
The tool/process controls nothing, it is used to meet the requirements on the drawing. If you have a requirement it needs to go on the drawing.
Read paragraph 1.1.41 closely before you start talking about the figure being incomplete etc.
As to the symbol, are you serious? It's a clarification. If you have a cross section as figure 5-37 has then yeah it's pretty clear which diameter and depth is which. Without the cross section it may not be clear.
RE: COUNTERBORE
RE: COUNTERBORE
RE: COUNTERBORE
RE: COUNTERBORE
Chris
AutoCAD 06
RE: COUNTERBORE
What if the depth tolerance were sufficient to allow a csk to be acceptable? Again, it seems that the CBORE tool controls the angle of the seat and additionally the corner radius. Radius not previously mentioned in this thread, if I am not nistaken
RE: COUNTERBORE
Even taking that into consideration, I'm not sure what the dilemma is regarding the seating of the screw head. The axis of the hole will govern the orientation of the bottom of it and the axis is controlled by the tolerance in the FCF. I don't really know why you are so hell bent on eliminating the CBORE symbol from the standard. I suppose you think CSINK should go with it.
I make the above comment in a quasi-jovial manner. I don't intend disrespect, I'm just a little amazed at how this point is being belabored...and I'm guilty of perpetuating it.
Anyway, I won't belabor it any more.
Powerhound
Inventor 2008
Mastercam X2
Smartcam 11.1
SSG, U.S. Army
Taji, Iraq OIF II
RE: COUNTERBORE
You can't really take the figures at face value for anything more than the specific point they're trying to illustrate, and even then in this case there is the zone/zones ambiguity.
ewh (and ctopher) explanation for the cbore symbol is even better than mine.
If you must insist on taking 5.37 literally then... There is no indication of where the cross section is taken/where it shows. i.e. There is no section line "A-A" and the section itself doesn't say "Section A-A" so there, the Cbore symbol is needed so we know it's a Cbore and not a CSK or even a male feature.
Gary, sorry my misunderstanding of your viewpoint.
RE: COUNTERBORE
The angle has to be in the limits of the depth tolerance. For extreme angles then the orientation of bore will control how the screw sits as Powerhound points out.
The corner is sharp within any relevant tolerances or drawing notes about sharp edges etc.
There's no guarantee a cbore bit will be used to create the cbore hole, it's just as likely these days to be a 2 stage operation with an endmill for the cbore.
Sorry, got a bit carried away there. Powerhound probably has a point, the smell or rotting equine flesh will soon fill the air, que ewh with his favourite emoticon.
RE: COUNTERBORE
http://www.draftingzone.com/shoppingzone/6-1.pdf
Chris
AutoCAD 06
RE: COUNTERBORE
The symbol is redundant.
Gary
RE: COUNTERBORE
If the depth tolerance were sufficient to allow a csk or a drill pt to be acceptable you would be better off specifying a counterdrill, for which you don't need a symbol.
RE: COUNTERBORE
Thanks.
I did a quick check on CAD of the example in the Standard and the tolerances on the example allow an angle on the seat of approx 15 degrees off horiz. (Worst case).
RE: COUNTERBORE
Powerhound
Inventor 2008
Mastercam X2
Smartcam 11.1
SSG, U.S. Army
Taji, Iraq OIF II
RE: COUNTERBORE
I did a recheck and with a triangle of 1.554, .4, and 1.5,based on the diameters and depth, I still come up with 15 degrees. What are your figures to arrive at 4.29 degrees?
I used diameters of 6.4 and 9.4 and a depth of .4.
RE: COUNTERBORE
This assumes constant angle across the dia of the C'bore etc.
What am I doing wrong?
RE: COUNTERBORE
This is only one side of the seat in the section view.
Does that make sense?.
RE: COUNTERBORE
Included angle of the csk about 150 degrees.
RE: COUNTERBORE
I only checked the deviation of the c'bore because as I said before, it is a separate feature. I drew the counterbore at LMC to get the largest amount of deviation so the diameter is 9.6, which makes the tolerance zone .45 in diameter. If you draw a line from X-.225 Y0 up to X.225 Y6.0 (6.0 represents the depth of the c'bore) you will get an angle from 0 of 4.59 degrees. If you make the counterbore to it's MAX depth of 6mm, the angle is 4.29 degrees.
For the purposes of furthering the cause. I checked the entire depth of the counterbore and hole as if it were one feature and came up with the same thing as KENAT.
What are we missing?
Powerhound
Inventor 2008
Mastercam X2
Smartcam 11.1
SSG, U.S. Army
Taji, Iraq OIF II
RE: COUNTERBORE
If I read this right, you are looking at the angle of the axis of the dia as allowed by the pos tolerancing. (I believe then your angle would be off the vertical) I am looking at the seating surface for the head, and looking at the worst case with dimensions provided. We are apparently looking at 2 diff things entirely.
My look at the worst case was assuming that we use this 'special toothpick' to generate the hole to the dimensions. This rather than a counterbore tool.
RE: COUNTERBORE
I'm also not convinced the included angle of 150 degrees is truely worst case. In this case the edges of the screw head will still sit on a fairly even contact it will just be a very narrow ring, under a lot of load they'll probably brunel the cbore a bit. For many applications this probably wouldn't cause too much problem. In some it may in which case an extra/tighter tolerance should be called out on the drawing.
I'm pretty sure I've lost interest now.
