Easy 3 views - question needs answering
I open a part from a customer and the (ucs is located way far away from the part itself.) How do I relocate this so when I start a drawing my part isn't way out in space. Can I make it so it is the axis' line up to certain flat edges on the part?
Isaac
RE: Easy 3 views - question needs answering
First create an axis in 3D as you wish you had it.
Then in Drawing select the icon to create the view, then in 3D select the new axis from the tree, then pick a face to create the view.
The axis view will be the preselected 3d axis.
Eric N.
