Teflon Rod
Teflon Rod
Teflon Rod
Does anyone know where I can buy teflon rod in 1/16" increments from 1/16"-3/8"?
RE: Teflon Rod
McMaster-Carr has them down to .125"
Don
Kansas City
RE: Teflon Rod
http://www.wmberg.com/ has Delrin 500 shafts in 1/16"
Heckler   americanflag
Sr. Mechanical Engineer
SWx 2007 SP 4.0 & Pro/E 2001
      o
  _`\(,_
(_)/ (_)
This post contains no political overtones or undertones for that matter and in no way represents the poster's political agenda.
RE: Teflon Rod
Thanks gents. I am trying to talk the coworker into delrin,
but I am not sure what his use would be yet.
Adam
RE: Teflon Rod
There's a big difference between Teflon and Delrin.
Don
Kansas City
RE: Teflon Rod
Yes, but in this case I believe it is the slipperyness
that is being looked for.
RE: Teflon Rod
Johnson Industrial Platics or Pacific Plastic here in Edmonton, Alberta Canada.
Wear a coat....winter is coming quick this year.
Kenneth J Hueston, PEng
Principal
Sturni-Hueston Engineering Inc
RE: Teflon Rod
There are other plastics to consider 'pomalux' (there are a couple of other equivalents) is one I've used in an application that others may have used Delrin.  Probably more expensive though.
In my case it was worth it.
KENAT, probably the least qualified checker you'll ever meet...
