cold roll with hardness of 30 to 50 HRC
Does he exist a cold roll who can undergo transformations ( laser cutting, welding and nickel plating ) and hardness of 30 to 50 HRC without quenched after transformations ??
RE: cold roll with hardness of 30 to 50 HRC
What kind of alloy are you looking for? Plain steel, stainless, Cu alloy?????
Still trying to help you stop corrosion.
formerly Trent Tube, now Plymouth Tube
eblessman@plymouth.com
or edstainless@earthlink.net
Hi EdStainless,
I'm looking for a plain steel or any kind of alloy in sheet metal ( 0.187" thickness ) but just in steel family.
Best regards
In my (admittedly limited) experience attaining a Strength on Hrc 30-50 is only possible with a quench and temper treatment. Obviously laser cutting and welding will create a HAZ around the area the operation is performed.
