Concrete Roof Penetration
I recently read somewhere (don't remember where) a suggested max concrete core diameter in relation to the deck thickness. Has anyone seen this recommendation?
Does anyone know a publication which addresses the performance of concrete deck slabs with varying size full depth penetrations (with or without steel sleeves)?
Thanks.
Thanks.
RE: Concrete Roof Penetration
For composite deck, check out:
http://www.sdi.org/whites/DDP.pdf
http://www.sdi.org/whites/FORM.pdf
For flat slab, check out:
http://www.concrete.org/members/ci2807mota.pdf
http://www
These are focused on larger penetrations but do have relevance to smaller ones.
csd
Have any leads on information on penetrations in one way cast slabs (with beam supports)?
