Is it applicable EJMA for flanged & flued type exapnaion joint?
As i know, The EJMA shall be subject to Appendix 26 in ASME Sec VIII. div.1 because EJMA is used only for bellows when designing the fixed type heatexchanger with latest edition. but our costomer ask us to use EJMA for flanged and flued type expansion joint which is as per Appendix 5.
So we are wondering that EJMA fomula is applicable for the flanged and flued type exapansion joint or not.
Please advise me for this matter.
RE: Is it applicable EJMA for flanged & flued type exapnaion joint?
See also: http://www.eng-tips.com/viewthread.cfm?qid=177673
and: http://www.eng-tips.com/viewthread.cfm?qid=185453
Regards, Mike
If 9th Edition TEMA Standards is published..Paulin Research was contact by TEMA for FEA program EJMA for flanged and flued type expansion joint for heat exchanger.
L.S.Thill
Mike
