Aluminum T6 Limitations?
I'm planning to use aluminum (Grade 6061 T6 / 6082 T6) for low temperature equipment skids (-20 to -40 degC).
Are there any recommendation / limitation for these materials at such low temperatures (resilience...) ?
Thanks and regards,
RE: Aluminum T6 Limitations?
Alloy 6061-T6 has an increase in yield strength, tensile strength, elongation, and fracture toughness when decreasing the temperature, even to cryogenic  temperatures like - 200 °C.
When you use the word resilience, do you mean the technical definition of "the amount of energy stored under elastic loading"?  If so, then you can examine the governing equation:
resilience = σ2/2E,
where
σ is the elastic stress limit
E is the elastic modulus (Young's)
At - 40 °C, the yield strength increases approximately 10 MPa and the modulus increases about 2 GPa, so the resilience will increase slightly.
Cory
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips Fora.
T6 is susceptable to stress corrosion cracking.
