Stirrups in Lintel Beams
Are stirrups typically used in lintel beams?
I have designed a 4' span and a 12' span lintel, and both meet requirements (MSJC-05 STR & ASD) without stirrups. I just find it a little unsettling not having stirrups, but if this is common practice I can leave the design as is.
RE: Stirrups in Lintel Beams
I prefer NOT to use stirrups but if it needs stirrups I don't hesitate. Make sure that you require monolithic pours if you have no stirrups.
In lintels less than 12" in width, I use only single leg stirrups. Keep in mind, that the minimum stirrup spacing for 16" deep is 6" spacing and 24" deep is 10" spacing.
I don't use stirrups either unless required.  If they are needed, then it is what is is.  The factor of safety is high enough I don't personally feel worried about leaving them out.  It's common practice in my area to leave them out.
