brass as a sealing surface?
One of our sister companies is experimenting with using red brass (not sure of the exact grade) as a primary static sealing surface for a product continuously submersed in sea water (100-200 ft depth typical).  From past lives I recall a patina developing in a short period on other products in these environments that make me question the integrity of the proposed seal but I have no direct experience with this exact combination.  Any experience to pass along would be helpful.
thanks
RE: brass as a sealing surface?
Red brass will not be long term stable in seawater.  At least not without significant cathodic protection.  You would need 70/30 CuNi to have long term corrosion resistance in seawater.
Still trying to help you stop corrosion.
formerly Trent Tube, now Plymouth Tube
eblessman@plymouth.com
or edstainless@earthlink.net
thanks for the help
