I'm lost!
I'm lost!
Don't laugh at me!
I started out using Microstation when it FIRST came out, back in the 80's. Then the company I was working for started using AutoCAD, which I detest.
Now, I've got a chance to move to another company which uses Microstation exclusively. I've trying to convert my thinking BACK to my baby, but when I first opened it up, it looked foreign to me!
I can't figure out how to draw a simple rectangle. :( Another thing I can't figure out is where the command line is so that I can put in the exact dimensions for this rectangle. If someone can PLEASE point me in the right direction, I'm sure that it will all come back to me pronto! This would be Microstation V8XM.
Thank you.
Thank you.
RE: I'm lost!
to place a polygon in XM if you've still got the default icons placed left and right try key board speed keys U 1
this is the keyboard short cut to the place polygons, place block...
I suggest you go to the help, contents, whats new
and read or print out each section this is basically the same as the coarse contents of XM familiarisation for V8 users...
RE: I'm lost!
RE: I'm lost!
Namdac
RE: I'm lost!
Accudraw replaces the need for the old keyins of DX= and so forth.
