Software for producing circuit schematics
  I'm looking for software that will run under Linux, preferably, that is free, but will allow me to produce  rudimentary circuit schematics.  The problem is that every piece of software I have found thus far seems to be focused on electronics.  I want something that will allow me to do panel circuits, with pushbuttons, contactors, overloads, control transformers... that kind of thing.  I don't need anything terribly swanky, just something a step above scribbling it with a pencil.
Mike
RE: Software for producing circuit schematics
Don't look for schematic software, then, look for flowcharting diagram makers.
Dan - Owner
http://www.Hi-TecDesigns.com
Bentley MicroStation used to have a Solaris release, not sure if they have / had a Linux equivalent. I'm pretty sure Autodesk have abandoned the Unix platforms. You might be able to pick up an older release of MicroStation at a bargain price. At the time I was using it it was a better product than AutoCAD of the same vintage. Something to investigate anyway.
Sometimes I wake up Grumpy.
Other times I just let her sleep!
Hiya-
Point your browser to:
http://www.geda.seul.org/
and grab the package.  It is a fairly high number of required chunks of extra software that should be loaded to install this
package, but it seems to work pretty well for me.
Gschem is the schematic capture program, and works o.k.  It is  easy to add new parts to the library and does all the simple stuff that is required.  PCB is the layout program and I use this all the time for layout of well, pcbs.  There is an interlinking between the two, and some autorouting available for PCB, but these are two features that I haven't used.
The packages seems to be actively supported and has a pretty good feel to it.  The learning curve for both were pretty good and although I found the PCB to be a little more intutitive, gschem works well enough for my needs.
  Cheers,
    Rich S.
Hiya again-
I guess that I forgot to mention that there is "generic" parts in the library that can be used for the "non electronic" parts like the contactors, pushbuttons and transformers. Sorry that
I had to double post this reply.
  Cheers,
    Rich S.
