Information about plastics online???
Does anyone know places in the WWW where information such as brand names, properties, uses, repeat unit of plastic materials are available?
RE: Information about plastics online???
Try http://www.azom.com natural language search tool plus trditional properties searches, should cover what you need
You can also check www.matweb.com
try www.polymersites.com for links to (hopefully) the desired info.
Try http://euler9.tripod.com/.  Browser Tip:  I found out you can kill pop-ups, and speed up your browser on quite a few sites, by turning off "javascript" (called "Scripting" in IE) in your browser options or preferences.  Once in a while, for a specific site, you'll have to turn it back on.  Also, browsing with images turned off, and only loading them on the pages you desire, speeds things up, too.
Try http://www.ets-corp.com/tradenames/tradenames.html. I had difficulties when using Netscape 6.xx browser. Explorer was OK.
Definately www.matweb.com Also I've included a materials section on our own website www.moulddesigner.com (which is overdue an update I know!
Kieran Fegan
Moulddesigner Ltd (MDL)
