Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...Thanks a lot Mate! I can't tell you how many times your site has saved my "rear". hehe..."
Geography
stanislasdz (Materials)
8 Sep 07 12:43
Hi all
i want to mesh an assembly of 2 parts. All it's OK and i export the result in the neutral format.
When i want to use it in a simulaion software. It recognize only one body ?
hwo can i do to mesh 2 body with concident nodes ?
Helpful Member!  40818 (Aerospace)
8 Sep 07 15:40
What do you mean by "using it in simulation software"?
I think you need to make it clearer what you are trying to do. Then i will be able to give you some advice.
9 Sep 07 11:35
Sorry my question seems to be not obvious
If you look to the picture you can see that i have two bodies to mesh but the nodes of the interfaces do not matches.
How to mesh 2 bodies with concidents nodes ?
40818 (Aerospace)
10 Sep 07 2:59
I'm not sure how the parts are physically connected to each other, but for your static case you could use boolean commands to merge your solids into a single entity, and then mesh. Your mesh looks pretty poor though, you will need a great deal more elements. You could also model and mesh the items separately and have relevent connector elements between them (RBE'S, CELAS etc) depending upon what best fits. You can also imprint your mesh onto the other item so in effect you could have coincident nodes.
Close Box
Join Eng-Tips® Today!
Join Us             Close
