VB6 - how do I get a list of Models used in a draft?
Hi everyone,
I'm using VB6 to get the models that are used in a draft file, but I'm not sure how as my VB experience is quite limited.
We have several projects, each new one created from a previous. Sometimes we have found that the new drawing is looking at the previous project model so I would like to interrogate each draft file in a directory and list the model/models that are used to create it.
Can anyone help me with the procedure to do this ?
bc.
RE: VB6 - how do I get a list of Models used in a draft?
bc,
maybe the following program does what you want;
check draft
The language has to be changed to English. The readme.txt is not fully
translated into English.
dy
Thanks Don,
Not quite what I was looking for but I've sorted it now.
I've butchered a copy of the existing SE Batch plot/convert program to do what I want.
It works fine, and gives me a text file that lists each drawing and the models used to create it. It's usually a single model, but on fabrications we sometimes also detail components individually.
A simple search and replace for the path where the model should be just leaves the paths of incorrect files.
bc.
bc,
that's what that program, beside other things, does. The
files to create the drawing will be listed in the logfile
dy
Sorry Don,
I should have explained a bit better -
I found the interface a bit cumbersome and not really user friendly. Unless I got it completely wrong, you have to type in the path you want to search.
With the batch based one I can select individual files, folders and sub-folders and define my own log file names at run time, so that I can split up proessing and review of log-files into manageable chunks.
Our projects typically comprise 900-1000 drawings.
We still can't get through to our client that it's wasting a lot of money copying models and drawings repeatedly for new projects - even when they are EXACTLY the same part as the previous project. Usually the only things that change are the title blocks of the drawings.
Thanks again.
bc.
AFAIK you can use Drag & Drop even a bunch of files/folders
Upon Start a log will be created otherwise data will be appended to the existing file
dy
