Calculating GMAW time to weld ?
Is there a simple calculation to help figure out weld times? For example I would like to know how long it would take a robot to MIG weld a fillet 2mm x 45 deg 26mm long. I usually just use 30ipm as a general welding speed but with such a small weld I'm not sure. Any ideas ?
RE: Calculating GMAW time to weld ?
Using that information and calculating the volume of weld needed, you should be able to calculate the time required to make the weld.
Best regards - Al
