Newmark analysis
Newmark analysis
Thanks for your help guys! It is my understanding that when performing a seismic slope stability analysis via Newmark the purpose is to calculate the permanent deformation for the slope in case instead of a factor of safety as in the pseudostatic analysis. However, once this deformation is calculated, what do we compare it to? What is the allowable deformation criteria? Do you know any sources I should consult for this allowable deformation? Thanks!
RE: Newmark analysis
http://
This is a very good document. To my knowledge, most of the public agencies have not mandated the method be used. One of the main reasons is that the amount of "allowable deformation" is contentious.
If you don't already have it, ask for a copy of the geotechnical guidelines from the reviewer's agency. If they have such a document, see if the Newmark criteria is in it or even mentioned.
