Mutlibody Part to Assembly File
Is possible to create an assembly file from a multibody part? The part files in the assembly are the bodies from the multibody part.
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: Mutlibody Part to Assembly File
Jeff Mowry
www.industrialdesignhaus.com
Reason trumps all. And awe transcends reason.
If so, right click the Solid Bodies and select "Save Bodies". It will save each body out to a part file with the option to create an assemby. All files remain linked to the original master.
Jason
SolidWorks 2007 SP4.0 on WinXP SP2
SolidWorks 2008 SP0.0 on WinXP SP2
Jeff Mowry
I was able to use the "Save Bodies" technique. It works well. Thanks!
Jeff Mowry
Jeff Mowry
