Group Bodies
Group Bodies
Hi all,
is there any way of grouping different bodies within a CATPart into a goup, but not assemble them using booleans? Something similar to a sub-product, but inside a single file... I know it was possible in UG...
Best regards,
Stely
RE: Group Bodies
RE: Group Bodies
The design intent of Catia - 1 partbody = 1 part. You can run the software with many solids in 1 file, you will loose the advantages of assemblies.
Derek
RE: Group Bodies
I do not use Hybrid Bodies.
I understand bodies as solid.
You can combine solids with boolean operations.
But I do no know anyway to have all solids as one without bolean operation.
Can I ask you why you need this ?
RE: Group Bodies
RE: Group Bodies
Received a tool assembly from another company, came as parasolid. Converted it to step, imported in catia and got a single file with all the bodies in the tool... We don't really need to build an assembly right now, so I was wondering if I could just somehow group toghether all the bodies from the upper side of the tool, and in another group all the bodies from the lower side... A faster method was to split the bodies in 2 files, one for the upper side, one for the lower side...
The main reason of my question was if there was any "hidden" way to do this, since in ug it was so simple... I am a catia "fan" myself, I didn't particulary like ug, but in some regards it was better...
Thanks for the suggestion, Jakk!
Best regards,
Stely
RE: Group Bodies
Jim
RE: Group Bodies
Derek
