tungsten disulphide as an anti-galling agent on stainless steel
I am trying to find a relatively cheap and easy method of stopping galling occuring on two mating parts made of the same grade of stainless steel. There are no moving parts in the connection but they are subjected to high pressures. It is only apparant when we come to service the parts and try to seperate them, galling has occured. We stopped the problem with electroless nickel plating with ptfe particles but it is an expensive operation. A number of ideas i have come accross are interesting, these being:- tungsten disulfide powder, can be polished into the surfaces of mating parts or air blasted onto mating parts, apparently completely eradicating galling, also using slightly different grades of ss will help. Does anybody have any info to verify the introduction of these operations and if so where i can purchase them from. Cheers
RE: tungsten disulphide as an anti-galling agent on stainless steel
Here are two suppliers of WS2
http://www.rosemill.com/default.asp?pageid=27390
http://www.dynacron.com/index.html
Here is a supplier of BN coatings
http
You need to look a SS material like Nitronic 60 or Gall-Tough as mate for one of your components. Both materials are inherently non galling and exhibit good wear properties while maintaining good corrosion resistance.
Jim Treglio
