CORRUPTED SW REGISTRY FILE
After I had a R.A.I.D drive and Windows SP2 installed, When I reboot my computer my Solidworks registry corrupts. I have to deleted it or run my Solidworks restore settings wizard.
Does anyone know how to fix this ??
RE: CORRUPTED SW REGISTRY FILE
Can't you uninstall your seat of SW and do a clean install?
"Art without engineering is dreaming; Engineering without art is calculating."
Have you read FAQ731-376: Eng-Tips.com Forum Policies to make the best use of Eng-Tips Forums?
There was a bug on this at the Knowledge base and it was in regards to the toolbars becoming in consist... If that is what you are seeing then I suggest you look the error message up in the knowledge base. Believe it or not it will require you to delete some DWG editor keys out.
Otherwise do a Clean uninstall of SW along with cleaning out the Registry.
Scott Baugh, CSWP pc2
www.scottjbaugh.com
Quote:
"If it's not broke, Don't fix it!"
I have sevral times.
drewf,
    You may not get this same message, but if this is your issue it is in the Knowledge Base, just like Scott said. Look at Solution Id: S-09461   Area: SR Originated
Question: Upon starting SolidWorks 2007 the error message, "Toolbar information is inconsistent, default toolbar setting will be used next startup" displays.  How can this be fixed?
Answer:
This problem is caused by corruption in the following registry key:
HKEY_CURRENT_USER\Software\SolidWorks\SolidWorks 2007\User Interface\API Toolbars
Deleting or renaming this key will resolve this problem.
To access the registry:
Click Start>Run, type 'regedit' and hit OK.
Locate the above named folder, right-click on the folder and select Rename.
Rename the folder to API Toolbars_old and close the Registry Editor.
Bradley
SolidWorks Premim 2007 x64 SP4.0
PDM Works, Dell XPS Intel(R) Pentium(R) D CPU
3.00 GHz, 5 GB RAM, Virtual memory 12577 MB, nVidia 3400
