Retrieve command listing from .db
I've got some .db files and I wish to manually edit my problem. I was wondering if there's a way to retrieve the log info or command listing from a db file.
Thanks in advance
RE: Retrieve command listing from .db
Hi
If you open the db file in ansys, you will be able to write out a lgw file. In this file all commands are listed.
To get the command lines from the db file it self will be a difficult matter, I don't think this is possible.
Garry
Even log file contains it
You can write out CDB file (an ascii command file)
CDWRITE
If you build future models using input files (*.txt, or mac for convenience) this issue can be eliminated.  This is a best practice that will come highly recommended from experienced analsysts.
Ansys is not by default a parametric based modeling program...infact it is one of the poorest tools one could ever use for modeling.  The answer to your question is no.  Unless you have the log file; or if the one you want has already been overwritten you're up a creek without a paddle.  You have two options:
a) Start over from scratch.
b) If you started w/ CAD geometry you could export any areas, lines, etc from your current database using IGESOUT and read these into the fresh CAD geometry in order to modify the database as needed.
Hope this helps.
Thanks for all the replies.
I tried both the CDWRITE and the LGWRITE commands. Both produce a log file full of garbage. Running the log file did not reproduce geometry, mesh or loads, as available in the original db.
Starting from scratch.
Wareva,
I dont know what it is you are trying to modify in your existing model....
You could generate an input file from the DB using
*cfopen,inputfile,inp
alls
nnn=ndnext(0)
*dowhile,nnn
   *vwrite,nnn,nx(nnn),ny(nnn),nx(nnn)
   ('n,',F5.5,',',F10.10,',',F10.10,',',F10.10)
!check your fortran format
   nnn=ndnext(nnn)
*enddo
!(make similar loop for elements and nodal loads...)
*cfclose
Needless to say that you will loose your solid model and parametric geometry if you do the above.
Could you be more specific as to what 'garbage' is defined as?  Does CDWRITE function properly?  I've never had problems with it.
If you choose to take eelco71's approach and export everything to an input file I'd recommend using the *cfwrite command over *vwrite for this application.  It's much more user friendly :)
Good luck!
As i said, the CDWRITE and LGWRITE commands did produce a log file. Although filled with commands, running the file did not reproduce the original geometry, entirely built on the Ansys GUI. It drew some lines, and it output lots of errors.
To my knowledge, the log file is session dependant, not file dependant. Therefore the cdwrite and lgwrite commands will simply produce RESUME,'file','db','directory',0,0
Of course not very usefull.
Selection in GUI by picking will produce KSEL,S, , ,P51X , also not very usefull.
