Reducing plastic waste at sheet extrusion company
We are sheet extruder and we generate about 10% waste through edge trim and floor sweeps and purgings. we do recover about 5% by grinding the edge trims and putting back in the blends. But it still adds grinding time, reprocessing costs and machine hr cost. I want to know how some have overcome these? also how to avoid lot of floor spills and die purgings which account for almost $400 a week.
RE: Reducing plastic waste at sheet extrusion company
The very general answer is optimise your process and improve your materials handling and housekeeping.
I guess you control the width before trimming by extruder output and roller speed and pressure or clearance settings. If so reducing extruder output and roller pressure will reduce edge waste. If the rollers are set gap rather than pressure, leave the gap but reduce output.
If you overdo this, you will end up with 100% waste rather than less than 5%.
re purgings, careful attention to production scheduling and correct technique are possibilities. Also, the screw and barrel clearance should not be excessive and the die and die plate should have no hang ups. A sheet or so called Coat Hanger die should be pretty straight forward and if in good condition should not be a problem.
You may need to remove the die face for major colour change purgings. If you remove the dieface, use a gas torch to burn out any material on it.
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips Fora.
The time involved and the readjustment of the puddle can take some time, so it would only be feasable on a lengthy run.
