Post Installed Concrete Anchors
For buildings, the governing code (IBC) sends you to ACI 318 Appendix D for post installed concrete anchors which only allows you to use approved anchor types (widely used adhesive anchors are not included as an approved type). My questons is, when using post intstalled anchors on bridges, does AASHTO also send you to ACI 318 Appendix D, requiring you to use only the approved anchor types also?
RE: Post Installed Concrete Anchors
What are you using the anchor for? Load types?
I would contact Hilti or Simspon Stong tie as they are the farthest along with their work towards approval and go from there.
Engineering judgement is certainly still governing, but we must respect the codes.
Unless we missed your question entirely - are you just wondering if AASHTO references ACI318-05? I don't have a copy of the 07 revision, so I can't answer if that is the question. Anyone else?
Daniel Toon
