Fabrisim Simulator
Fabrisim Simulator
On the Amada FO3015NT you have a progamming program called "AP100US". Recently we recieved out Fabrisim licence, so i installed it and got the simulator up and runing. When it came to running the simulation an error came up informing me that i was in the "Dead Zone", this i understand as on the FO control you can turn the dead zone off.
So my question is how can i turn this off on the simulator, when i read the help menu, this option is only available on the punch press side and not on the FO option.
Appreciate any help with this problem, if it is not possible what is the point of having the simulator set up for a FO, if you cannot run the program to get an estimation of how long it will take to cut your parts.
RE: Fabrisim Simulator
