welding a 3/4" wt Float Shoe onto a 1.5" or 1.0" wt 30" Casi
We have a 3/4" float shoe to be joined to a casing that's either 1" or 1.5" thick. The O.D are both 30" but I'm concearned about the difference that would occur in the I.D at the welded area.
RE: welding a 3/4" wt Float Shoe onto a 1.5" or 1.0" wt 30" Casi
Hi novice
Could you give more detail ie materials,physical size etc
desertfox
both materials are 4130 @ a 30" diameter.
