Add Component to Simplified Rep
Hi all,
Is it possible when working in Assembly, to add a component to only show in the currently selected simplified rep?
At the moment, if I add a component to the assembly, regardless of what rep I am currently in, I then have to go through all the existing reps "excluding" the new component.
Many thanks.
RE: Add Component to Simplified Rep
Sorry maybe I should add it is WF2.
Cheers
No, by default, Pro/E addds new components to the Master rep and they show up in all the other reps.
Ben Loosli
Thanks for that. That's a shame as if you have a big assembly and work with many reps, sometimes you just want to add a component to one rep. You then have to go through all the other reps excluding the new component.
Cheers.
