Helical piles
Helical piles
I have several projects that will require helical piles. I'm am looking for a design forum or formula that will give me the basics of helical pile design.
Thank you
Thank you
RE: Helical piles
thread585-87723: Underpinning and New Construction Piers
thread256-169263: Helical piers instead of drilled piers?
RE: Helical piles
These are usually designed by the contractors PE, it probably worthwhile checking this out before you spend time designing them.
The connection to the footing is up to the structural engineer though.
csd
RE: Helical piles
Suggest you let a local geotech and/or helical pier contractor advise you on foundation type and constructability.
Jeff
RE: Helical piles
RE: Helical piles
http:/
csd
