Question on helix
Question on helix
I have a fairly small variable pitch spring using a helix and about 50 revolutions. It takes a bit of time to save, rebuild etc. Is it video card, RAM, or processor speed that determines this time? I have a high end VC and a 3.0 Ghz Xeon processor, with 3Gb of RAM.
Thanks for any input.
RE: Question on helix
Jeff Mowry
www.industrialdesignhaus.com
Reason trumps all. And awe transcends reason.
Jeff Mowry
Looks more like constant-pitch, variable diameter...
Swept helix will take lots of crunching, no matter what.
If you are not actually engaged in manufacture of spring, I wouldn't bother. No appreciable gain for your pain. Just model the exterior & interior "envelope" surfaces. Use texture or thread if it makes you feel better.
p.s. nice model
http://www.EsoxRepublic.com-SolidWorks API VB programming help
Jason
SolidWorks 2007 SP4.0 on WinXP SP2
So many ways to do things. The way I mentioned above comes in handy if you need your helix to follow bends and curves.
Jeff Mowry
HAAAA!
Jeff Mowry
My rebuild time with verification off is 2.13 seconds.
My forced rebuild (Ctrl-Q) time is over 2 minutes
Here is a picture of the entire model. It is a "K" type thermocouple. I will upload it to 3D Content Central today.
It's simulating 85 turns. Total rebuild time 1.05s according to Tools->Feature Statistics. File size is about 700kb.
Thanks much for your skilled input!
Saving the file takes around 5 seconds to my hardrive.
My PC:
Intel Core2 6300 1.86ghz
4gb ram
Nvidia Quadro 3500 graphics
Winxp sp2
SolidWorks 2008 sp0
Jason
