corelation of Subgrade modulus and bearing capacity.
is there any corelation of bearing capacity and subgrade modulus. if the bearing capacity is 2 ksf, then can we deduce subgrade modulus from this value ?
RE: corelation of Subgrade modulus and bearing capacity.
thanks a lot SlideRuleEra very usefull link.
According to Joseph E. Bowels,
Modulus of Sub-grade Reaction = S.F. x 40 x Bear. Cap.
Usually S.F. = 2.0
His book "Foundation Analysis and Design" is a useful guide in designing foundations. You'll have to consider two values (one higher and other lower) for the spring constant.
Clefcon
Contact the project geotech or a geotech and ask him/her.  Subgrade modulus has to do with soil displacement as well.  If you have so much displacement under a certain bearing pressure, that correlates to the subgrade modulus for that condition.
Also, subgrade modulus is tested based on a standard size plate bearing. If the size of the footing is significantly larger than the size of the plate, the modulus needs correction.
