testing welded stainless steel connections
Are the following valid tests for welded connections of stainless steel?.....I have been grinding on this for awhile with little result
a. Liquid Penetrant Inspection: ASTM E165.
b. Magnetic Particle Inspection: ASTM E709; performed on root pass and on finished weld. Cracks or zones of incomplete fusion or penetration are not acceptable.
c. Radiographic Inspection: ASTM E94 and ASTM E142; minimum quality level "2-2T".
d. Ultrasonic Inspection: ASTM E164.
thanks for any input...its for a spec I am commenting on
RE: testing welded stainless steel connections
