Perpendicular tension loading in truss connections
Hi everyone. I've used this forum often and have found lots of useful information. This is my first posting so please bear with me.
A colleague of mine and I were discussing the issue of perpendicular to grain tension loading in a wood sill plate. We're all taught to avoid this type of loading condition, but what happens in a truss when this occurs.
Take a simple "A" frame truss with an elevated bottom chord that is vertically loaded. The bottom chord is bolted to the top chord at its ends. Once the truss is loaded and the bottom chord goes in to tension and pulls on the top chord, doesn't this produce a perpendicular to grain loading on the top chord. It may only be a small portion of the load in the bottom chord but how does the code (IBC, NDS,…) resolve this? Are my colleague and I missing something?
Thanks in advance for any advice.
RE: Perpendicular tension loading in truss connections
woodengineer
ctcray: Good comment. I know this condition occurs in wood floor systems all the time. Say for instance, you have a large GLB (5.125x16.5) with another floor girder framed into it (4x12). Unless a top flange hanger is used to support the 4x12 it would seem a face mounted hanger would produce tension perpendicular to grain. I don't remember seeing the reduced loads in the Simpson catalogue, but I'll look again.
CJSchwartz: I agree. Something should be added to the connection or the connection should be modified to avoid the tension stresses. Although, I can't remember ever seeing a truss with a connection that had something unique or unusual. Everything I have seen looks like a standard plate connection. I would think in order to eliminated the tension loading the plate connection would need a backing plate similar to a Simpson "GLS" hanger.
Woodengineer: I agree. When ever possible the beam or truss should be loaded above the its centroid.
Maybe this is not such a big issue with a "built-up" truss or the "A" frame I described in my earlier message. What I mean by "built-up" truss, is a truss built with a 4x top chord and a 4x bottom chord all connected with steel plates. In this scenario, all the connections should have the bolt groups centered around the top and bottom chord centerlines so as not to produce eccentric loading in the joints.
The Timber Manual, 4th edition, shows an example of a wood truss, but only the connection with the compression loading is shown. Later, in Chapter 7, there is the usual comment about tension loading perpendicular to grain should be avoided.
I hope I'm not over thinking this, but it would seem there would be some type of documentation on this somewhere.
Thanks again for the advice.
