Static and Fatigue properties of 21-6-9 Cres Tubing
Looking for some static and fatigue properties for 21-6-9 Cres tubing.  The information needs to be public domain and referenceable.
Thanks for your help.
jetmaker
RE: Static and Fatigue properties of 21-6-9 Cres Tubing
heres a little information that might help.
A specification that defines 21-6-9 tubing is AMS 5562. I assume you have access to this. UNS number is S21904. I don't have access to the AMS spec any more so I can't say if it gives the mechanicals.
Getting the fatigue number is a tough one. My Carpenter book gives a yield strength of 52 - 62 Ksi for an annealed bar depending on size and test direction. There is also some data on cold drawn wire but again nothing on fatigue. suggest you contact carpenter directly.  http://www.cartech.com/
A few years back I used the following source for some 304L and 21-6-9 tubing in the 2" and 3" range. Don't know if this sales rep. is still there.
Future Metals Inc.
10401 State Street
Tamarac FL 33321
800-733-0960
Margaretanne Fineo
www.futuremetals.com
AMS 5562 is solution treated tube. Min Ftu 90 ksi, min t2 50 ksi. e = 45%.
AMS 5561 is cold drawn tube (either seamless or welded). Ftu 142 - 162 ksi, t2 120 ksi. e = 20%.
No fatigue props in ASMH. Could try Atlas of Fatigue Curves or SAE Fatigue Design Handbook. Note that 21-6-9 is aka Nitronic 40.
