A516 Grade 70
A516 Grade 70
A516 Grade 70
Is there a suitable substitute for A516 Gr 70 steel to be used in low temperature (-44 F) applications?  A516 Gr70 only comes in sheets, and I have some structural shapes (platforms and ladders) that need to perform under these low temps.
RE: A516 Grade 70
ASTM A 516 Grade 70 material is supplied in plate form, not necessarily sheet product form.  So, I don't see a problem.
Regarding ladders, there are ASTM specifications for fabrication of ladders based on OSHA requirements.
Suggest you review
F840-83(2003) Standard Specification for Ladders, Fixed, Vertical
