A105N versus SA105N
A105N versus SA105N
Hi everyone,
Do any of you know if there is a difference between A105N and SA105N carbon steels ?
RE: A105N versus SA105N
Revised 12.2.2 to require reporting the width of the gage length of longitudinal strip tensile specimens, if they are used.
If this change does not affect you, then the two are the same. The ASME version usually lags the ASTM version.
