NX4 ON VISTA BUSSINESS 64 BIT
Does any one can help me?
I having some trouble instaling nx4 on vista 64bit.
Does any one allready install nx4 or nx5 on vista 64Bit.
Please help me on this one: I really need to get it work as fast as possible.
RE: NX4 ON VISTA BUSSINESS 64 BIT
I'm running NX5 on Vista64.  What seems to be the problem?
-Dave
Everything should be designed as simple as possible, but not simpler.
NX4 is not supported on Vista.
Ben Loosli
Well I don´t known what´s wrong Nx just doesn´t start: I still believe that nx4 should work on vista and that there are people who managed to make it work.
I apriciate any help to make run nx4 on vista~
Have you checked on GTAC boards at all?  I think it's been talked about on there.
We still have XP SP2 and no plans on upgrading to Vista anytime soon.
Justin Ackley
Designer
Just right click it, go to properties, in properties click the compatibility tab, then check Windows XP mode. Should work.
Are you running the license server on Vista64 too?
I didn't have to change compatibility mode with NX5 on Vista64.  I don't have NX4 loaded on this machine.
-Dave
Thank people
I finised the work in an another computer,
I hope that during this week I´ll have more time to test NX4 on VISTA 64.
So far NX5 WORK on vista 64
I´ll keep you inform.
Hi, this post is just to inform that nx4 is currently working on vista business 64 bit.
When installing nx4 on 64 bit there is and apllication for differente OS other than xp 32bit to install.
After installing it, will run with no problem.
Now I have other compatibility problem with my server but I hoping to solve those too.
bye
