Expansion Joint vs flexible joint
Dear Members,
Could any one has a thought about using flexible joint instead of expasion joint?
I'll appreciate your feedback.
Regards.
Dj364
Regards.
Dj364
RE: Expansion Joint vs flexible joint
What is the line size(es)
What is the product in the line?
What is the pressure?
What is the temperature?
What is the pipe material?
line size is 10", DesP 0.18 bar (2.6 psi), DesT=110 C (230F), pipe material Stainless steel (304/304L).
Thanks in advance,
Dj364
But flexible hose connot be modeled in caesar II programm ( beam thoery).
so I am mdeling at the point location as free end , with Axial anchor close and limit the operating lateral mvt to 3mm, and axial operating mvt 5 mm.
is it a good approach?
I will appreciate you do have other tips for modeling the flexible hose.
Thanks'
Dj364
