Sheet Pilings Connection
I am trying to install a new sheet piling system to connect at one end to an existing vinyl marine sheet piling. Very likely, I’ll be using similar material. Are there any standard joint or connection details that somebody can direct me to? I was thinking of an extended overlap but was concerned about the tie backs and encroachment into the adjacent property.
RE: Sheet Pilings Connection
kxa,
Very likely, the existing end sheet has the interlock knuckle still intact. Suggest you attach directly to the existing sheet, if possible.
Jeff
