Autocad 2008 file options
Can I back-file from 2008 to other versions such as 2000, 2004, etc? Thanks - Dadelar
RE: Autocad 2008 file options
do you mean "_saveas"?
Or *.bak files? -> No!
Lothar
ADT 2004
Exxit - Not back-up. I mean can I save-as a 2008 file to a 2000 or 2004 DWG format? I know 2008 saves in 2007 format but I need to go to both 2000 and 2004 for customer applications. BTW - one of my customers' claim that accuracy is lost when you DXF file. Is this true? (Is it obvious that I'm not much of an AutoCad man? I primarily work with SolidWorks or SolidEdge - haven't used AutoCad since the 2000 days...) Thanks - Dadelar
DWG true view 2008 will convert back to R14/LT98/LT97 drawings formats.
It looks to work the same as E-Transmit
You may have to EXPORT to an earlier version.  We have to export from Autodesk ABS 2007 and I'm sure we'll have to when we go to 2008.
AutoCAD 2008 will save as R14/LT98/LT97.
loss of accuracy can occur in dxf's if the precision level is set low.  All coordinates will be saved in ascii format with a fixed number of decimal places.  If you work with very small numbers or very high tolerance dimensions in yor drawings, you could lose some accuracy.
You can control floating-point precision of the DXF format up to 16 decimal places.  If that doesn't provide enough accuracy for your application, then dxf files will be less accurate.
Unless I am missing something, you should just be able to go to the "Tools" / "Options" menu and under the "Open and Save" tab select what AutoCAD version you want to save as.
