pressure relief valve setting
i'm trying to determine the correct setting for my Direct Acting Pressure Relief Valve. this is a hydraulic system which i know the accepted setting is 10% over MAWP. However, the valve in question is in an accumulator pressurized with nitrogen. i need to know if pneumatic relief valves have different setting standards than hydraulic. working with 3000 psi system. any info will help. thanks.
josh
josh
RE: pressure relief valve setting
Tom Barsh
Codeware Technical Support
jt
