mm/s vibration
mm/s vibration
mm/s vibration
I am monitoring vibration on a centrifuge and would like to know what mm/s of vibration means
RE: mm/s vibration
milimeters per second
RE: mm/s vibration
... probably RMS velocity.
RE: mm/s vibration
Vibration can be measured in terms of displacement, velocity and acceleration of the object.
What you are measuring is the velocity of the object/structure/whatever (due to the applied forces) in millimeters per second.
Aercoustics.com
RE: mm/s vibration
It could be in rms, peak, to peak, or zero to peak, or absolute.
It could be time averaged.
It will be frequency limited.
Cheers
Greg Locock
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips.
RE: mm/s vibration
GregLocock-
Are you British?
Tunalover
RE: mm/s vibration
perhaps because you said "zero to peak" as opposed to "zed to peak"
Aercoustics.com
